I built a QAV400 that flies well and records smooth video. I'm getting 10 minute flights using 5200mAh LiPo batteries.
I want longer flight times.
My Plan:
- Create a baseline using a standard battery.
- Reduce the weight of the "dirty" frame by 200g, maintaining strength and rigidity.
- Design the new, lighter frame to allow for 10" props (current limit is 8").
- Reduce the weight of the "clean" frame by 50g or more.
- Replace the original 1100kv motors with more efficient, lower kv motors.
- Document the performance of various prop/motor combinations.
- Find other ways to reduce overall weight/increase flight time.
Goal: To achieve 30 minute flight times while maintaining good flight performance.
I've been following posts by Forrest Frantz who currently holds the Guinness record for Longest Electric RC Multicopter Flight at 97 minutes!! He has some great threads with tons of info, especially this one on Building Copters with Round Tubes...
I'll be posting detailed notes and photos of each step...
Also, my Styrofoam pontoons were perfectly intact. This could be because the quad was upside down when it hit the ground but its also because I wrapped each pontoon with this fiberglass drywall joint tape. The joint tape is a white, open fiberglass mesh that is super strong and light. I used blue duct tape to attach the pontoons to the frame. Each pontoon weighs 32g (including the blue tape) and will float 2+ pounds.
So, I went to Virginia to visit my friend Jenna Kellen and we went to go fly my new frame. Everything was going well, until something caused my quad to literally fall out of the sky. I've edited the video down to less than 2 minutes so you can get and idea of my flight before the crash.
The good news is there was minimal damage. As planned, three of the motors were ejected from the frame on impact. This is because I'm using nylon bolts to attach the motors to the frame. Thanks to Forrest Frantz for that idea! I was happy there was no damage to the gimbal. Also, NO PROPS were broken!! Here's a complete damage report:
- (2) Broken receiver antenna masts
- (1) Broken GPS mast
- (1) Broken video transmitter antenna mount
- (12) stripped 3mm nylon motor mount bolts
Now the big question- what the hell happened? The battery was fine (I think). GPS appears fine (I was in Alt-hold mode when I crashed). If you listen carefully, it sounds like motors shut off, even though my throttle was up.
When we got back to the house, I attached the motors with some extra nylon bolts I brought with me. powered it up to see if there was an ESC failure or a wiring problem. The quad armed as usual and ALL FOUR motors started normally. I couldn't fly yet because I had no antennas or GPS mast. I repaired those a few days later.
I've been talking with Forrest and Hugues about the crash and while they have given me a lot of great information, no one is sure what happened exactly. If anyone would like to study the log from this flight, PLEASE go ahead! I'll attach the log to this post...
2015-07-28 17-36-55.log
The Lumenier 5200mAh 4S battery weighs 505g.
The GoPro HERO 3 camera weighs 75g.
I won't have much time for flight tests before my trip to Virginia, so we'll see what it does when I'm up there.
Great :) , waiting amazing videos ;)
Unfortunately, I crashed and I haven't figured out why. See my next post...
Finally, I cut holes near the center of the frame to feed the ESC control cables and accessory power wires through. Since the carbon fiber skins on the frame are only 0.008" thick, I added some 0.020" reinforcement around each hole.
1
2
3
4
5
of 14 Next
