ACM2 tricopter AUTO and ALT_HOLD test
3689414623?profile=original
3689414581?profile=original
ACM2-logs-2011-06-30.zip
ACM2-Tricopter-Config.param
ACM2-logs-2011-07-02.zip
I set the altitude to 18 - 28 meters high but it went to near 100 meters high,
I was a little nervous since I almost can't recognize how it's flying.
All I can do is trust ACM2, I have both sonar and compass on it.
I felt the throttle control response in ALT_HOLD mode is not sensitive enough.
I used the latest ACM2 code which was downloaded today.
Logs and config files are attached FYR.
  • What's your prop wear? between CW and CCW
    setting frame model who you wear?
    I'm trying to 3c as well. but there is a choice of frame "Options: [x, +, v]"
    which should I choose?
    please explain
    thanks
    Cliff,
    If you add a WP to head home or command to RTL at the end of the mission that would be great to see. Thanks.
    Grab the latest 2.0.33
    Jason
  • No problem, I'm happy to help testing and enjoying it actually.
    Just let me know what I can do about the test, I might not have much time to dig into the code.
    Here comes the vedio.
    Testing new Loiter values thanks to your logs!
    Jason
  • @ hsucliff,  You do a great job!
    I met  hsucliff many years ago~   I am also interesting in his ACM2  so we meet again today.
    About  today's waypoints flight,  I also feel ths altitude control is OK  but GPS_Position_Hold need more improvement.
    By the way,
    Here is the  aerial panorama of  test site which I used MK to make it.
    http://www.360cities.net/image/guang-fu-bridge-park-panchiao#424.54...
    Cheer,
    板橋 光復橋飛場 360 Panorama | 360Cities
    360° panorama photo from Taipei by Hung-Chin Wang. 720 degree fullscreen Aerial panorama of Guang-Fu Bridge Park, Banqiao Dist., New Taipe...
    Cliff,
    Thanks for the data! I think I can tune this to be even better thanks to your log.
    The last part is your copter loitering at the last waypoint. Put a WP at home and you should be good.
    Alt hold accuracy looked great.
    Jason
    3692232415?profile=original3692232577?profile=original
    hsucliff: thanks for the flight report. Sounds like we're making progress. Can you repost that log file? It didn't come through.
  • Tested with 2.0.31 this morning, the result is better, but the sonar ALT HOLD seemed still not good, logs file attached.
    My Tricopter seemed loiter arround waypoint 3 (last waypoint) before going back to home position.
    Shouldn't it loiter after backing home position? I eventually turned to RTL mode to call it back.
    I Will post video later.
  • whether it was safe in auto mode did on quadcopter?
    for ver 2.0.31?
  • OK. Thanks.
    Probably would have my tomorrow morning time to test again in Taipei.
    -Cliff
