It's been a couple of weeks, and now we have a new version on APM Planner 2.0 to download. If you are not following the the daily releases from http://firmware.diydrones.com/Tools/APMPlanner/daily/ which have the most up to date fixes as reported by our users. Please download the new version from here http://ardupilot.com/downloads/?category=35
Please report issues here http://ardupilot.com/forum/viewforum.php?f=82 and here https://github.com/diydrones/apm_planner/issues
Thanks, Bill
Same question is there any support yet for HIL simulation in APM Planner 2? I had several issue when trying to use HIL simulation in QGroundControl so I went back to Mission Planner to run HIL
Great work! Does it support HIL with X-Plane 10 ??
Thanks Bill. That is what I downloaded but then quickly realized that it might not support video on the HUD. Any idea if / when this will be implemented? I only use it for FPV so video on HUD is a must. Otherwise it looks great and was nice not having to boot up Fusion to run the PC version.
@Greg: Sorry it requires the QUAD to use the MAVLink protocol. Horizon Hoby are using there own protocol for GCS.
I would like to find out if this program would be compatible with the Blade 350 QX RTF from Horizon.
Thanks Greg
In the Installation instructions.rtf in the .dmg it explains how to open a non signed binary
Otherwise go to System Settings, Security and check the bottom option and choose from Anywhere.
Just chose option "open with" - tap two fingers on touch pad - and later you can open in the standard way.
@ jaceheli
How do you solved it?
Good old Mavericks
