In Bill's recent pod cast he talked about how the imudevboard experienced a random nose dive or extreme over estimation in the pitch (theta) axis. His theory was that the noise due to engine/aircraft vibration was causing the gyros to give inaccurate readings. He said that he put the imu in foam and the problem went away. I don't know how repeatable his experience was or how many test vehicles this "technique" was run on, but I find it no coincidence that I experienced the exact same effect on my imu.
Here is my theory:
I did some quick number crunching on some equations and found that it totally makes sense that pitch would "depart reality" more-so than roll and very rapidly as both him and I have both observed.
(edit)
For a 30deg AOB turn at about 1.5g's total the attitude solution if improperly estimated would be off in roll a couple of deg and about 30deg in pitch causing this nose dive affect.
(correction)
For a 60deg AOB turn at 2G's the estimation in pitch was off by 10 deg if centripetal was incorrectly calculated. The error would be in the positive direction causing the stabilty loop to push the nose over causing the "imu nose dive problem"
I was extremely surprised at how quickly pitch departed at very shallow angles of bank. So this lead me to suspect one thing beings my math modeled exactly what I was seeing in the air....centripetal. Here are the pitfalls I evaluated:
Gps latency
Gps bandwidth
Propper velocity mapping into components
So I will discuss in order
Latency. GPS has it...big surprise well how much is it and how much can it affect the solution. Depending on the module I have read 10seconds to about 0.5. Well for my Ublox it was about 0.75 to 1.5 depending upon the rep rate selected and positional accuracy (number of sats). I plotted it out and you can see how poorly the centripetal was accounted for in my "car test run". It's ok but in its worst case scenario could be off as much as 13 deg....which is better than 45deg with no centripetal at all for the runs I did. However 13 off and 1.5 seconds late quickly would cause things to go south
GPS bandwidth. Its at best 4Hz....need I say more. You are going to miss changes in speed quite a bit and loose a lot of accuracy. Also note the graph where GPS clearly is reporting the wrong speed at the wrong time
Velocity mapping: This is how you map the velocity into the actual body velocities. Most people assume that the speed reported from the GPS is always out of nose of the airplane. This is mostly true except for in climbs. It is safe to assume that the v velocity (out the wing) is zero but not the w (out the belly of the aircraft). The total of u and w are the SOG from GPS and you must break them up. I'm pretty sure the imudevboard code does this but if it doesn't this is another large source for mis calculation
All of these things together are issues that can clearly throw off one thing....Centripetal estimation which was why we determined there was a 30deg offset in our crappy estimation. So with that solved (use airspeed instead) the problem goes away. I have hours of flight time on my IMU both with and without GPS and the nonGPS filter has yet to diverge from reality under self stabilized flight. GPS filter on the other hand....it depended on the airplane the autopilot....amongst a lot of other random variables that never made sense like calendar day. Some days it was fine and others it wasn't on the same aircraft which leads me to my next topic.
Noise/Vibration:
Gyro drift is due to temperature. When I tried to follow the drift using an integrator in software we had issues. Same idea and same effects and just as random. Some days fine and some days not. The filter DCM or what have you is a very dynamic thing and if you try to model a temperature drift with an integrator (in my humble opinion) it will only work assuming that your other estimations are perfect. Else the other errors will map into your temp compensation.....which does happen no denying it. Its ok if your gyros don't move that much with temperature and you keep an eye on the integrator however its way too unpredictable of a problem to assume your error state is a fixed target....It simply isn't.
I run a temperature comp on my gyros and get repeatable results every time. With my comp equations the end result is a gyro that will hold itself +- 5 deg for 5 min or so. There are a lot of other tricks here like circuit noise reduction and oversampling that can be done but this is huge if you want to keep your solution converged.
As far as vibration.....If a gyro gave crap results because of vibration then it wouldn't be any use in a 6dof filter. Your accelerometers produce noise with vibration and hence the reason we use gyros. I just don't see any room for allowance of gyros to be noisy in vibration. Pick good gyros and temp comp them and so many problems dwindle away very quickly
update: addressing the airspeed question
My acceleration model
Best Regards and good luck in the IMU world
-Ryan
