MAV Pilot 1.1 for iPhone, Update released.
3689670250?profile=original
MAV Pilot v1.1 for iPhone has updated and published to the App Store. It supports connection to MAVLink compatible drones using WiFi (& LTE/3G connections) including 3DR Solo.
MAV Pilot supports Plane & Copter.
MAV Pilot v1.1 has the following improvements
- Maps
  - Support for more mission items with direct placement of Waypoints and ROI directly on map (long press menu)
  - Guided mode
- Improved Audio Support (Text2Speech, custom speech strings possible)
- Improved App Settings for Network Connectivity.-
- New attitude Indicator on Dashboard
- New analog displays  on Dashboard
- Map 'mini dashboard' of important information
- Servo Commands
- Support for ArDrone 2.0 with Flight Recorder GPS
- General UI improvements
Download here ( https://itunes.apple.com/us/app/mav-pilot/id649233096?mt=8)
Happy Flying... :)
Support here http://www.communistech.com/support/
PS: if you want to help with beta testing the next release, please contact me via the above link. Thx. Bill
    @Nisouck I did some further investigation. The issue you cannot add a mission item until there is a vali home position reported from the copter/plane. If you arm the vehicle, and disarm a Home mission item will be added. You can then add more mission items. I will fix this in the next release so if no Home Position set, it will create a place holder so a mission can be created. Thx for posting the question. Hope that helps :)
    Long press on the Map view will show a a circular context menu to select  a Waypoint (green icon), ROI (target icon), or '+' icon for Guided mode to that point.
    http://www.communistech.com/forums/forum/tech-support/ for support questions.
    Tech Support
    @Chris, No Android version of MAV Pilot at this moment in time, but you can use Tower on those devices.
    @Randy You can get the 'free version' if you download Find My Drone. It works similar, but doesn't have the extra features like mission planning, text 2 speech audio and parameter editing.
    'Free' copies are available to active beta testers. contact me if interested
  • Android?
    That's really cool Bill.  I'm not an iPhone user but it's great to see this!  $9.95 but as a friend once told me, "we all gotta eat!".
    3702118110?profile=originalHere's a screen shot of Plane support.
    MAV Pilot can connect over either WiFi or 3G/LTE to a single drone. It's just connecting using IP. It's either a TCP connection or UDP listening connection.
    By "WiFi (LTE/3G)", I assume you mean Wifi *or* LTE/3G, yes?
