ArduPilot has a built-in power regulator, so you can power it from a separate battery at anything from 5-15v. To do this, you have switch the solder jumper from the default RC power to battery power. This means unsoldering the solder jumper that the board ships with and resoldering it on the other side. These pictures show the difference (apologies from my crappy soldering on the second one):
One thing to keep in mind if you make this change: Unlike the standard setting, if you use BATT input it will only power the ArduPilot board; it will not power your RC receiver or servos. They must have their own power supply, such as a receiver battery pack or ESC for an electric plane. This is designed for people who fly gas planes (no ESC) and want the RC system on a separate power circuit so the autopilot can't drain that battery.
If, however, you want to to power both the RC system and the ArduPilot board from the same source, leave the board in its default setting and connect the battery straight to the RC receiver; the receiver will then power the ArduPilot board.
ArduPilot can be powered by the same power source as the others, as long as it's between 6-11v (ideally between 6v and 7.4v) and you've switched the power solder jumper.
okay guys..im confused here. im using the ardupilot for my blimp and am using the xbee wireless retail to tx motor commands from a groundstation/vicon system. so in this case i can just stick to batt power for my ardupilot as the rest of the onboard the airship(cameras,motors,) can be powered by another batt source? or can i integrate the power for the motors/cameras with ardupilot itself?
That's cool, but there is no voltage regulator in the schematics (v14 2008-11-18) or BOM on this or the Sparkfun site. :-( I guess the regulator is the mystery SOT23-5 near the BAT hdr? I have been wondering what that is...
