Over the last week, ResearchDrones.com and ConservationDrones.org conducted a series of tests of low cost thermal imaging cameras.
Models tested:
1. FLIR HS-324 Patrol 19mm Thermal camera (320 x 240 res) (link)
2. NEC F30 Thermal Shot Infrared Thermal Imager (160 x 120 res) (link)
Above: Flight tests (cloudy daylight, ~3 pm winter afternoon)
FLIR image taken by conservation drone from ~100 m above ground. FLIR camera tilted ~40 degrees downwards.
NEC image taken by conservation drone from ~100 m above ground. NEC camera was downward facing.
Ground tests (complete darkness, ~9 pm winter night):
Conclusion:
The FLIR is the clear winner in terms of picture resolution and thermal sensitivity. But the FLIR HS-324 is also much heavier and costly (~600 g, ~US$ 7,000) than the NEC (~300 g, US$ 4,000).
Based on these tests, we believe the ideal solution might be the more compact FLIR MS-324 (320 x 240 res) (link), which has the same resolution as the FLIR HS-324, but weighs much less (340 g) and is also more affordable (~US$ 3,000).
(*Note: We are not sponsored by the companies hyper-linked to in this post. The cameras we tested were either rented or on loan from colleagues.)
Impressive! Thanks for sharing.
Comment by lianpinkoh on January 5, 2013 at 11:57am Hooks, I believe so.
Comment by Hunter Parris on January 5, 2013 at 1:51pm $3K isn't bad for the 320x240 resolution. I'm waiting for SPi to come out with a sUAV FLIR camera ready for flight!
Comment by Jesse on January 5, 2013 at 4:55pm I *seriously* want a thermal camera :-(
Comment by Simon on January 5, 2013 at 5:21pm Joshua Ott: we thought we'd go for as much CPU power we can get with the antenna tracking.
Comment by Josh Potter on January 5, 2013 at 5:51pm FLir 320 x 240 30Hz NTSC $2,500
Weight is 360 grams (.8 lbs)
I think this is the same camera in that handheld one but with the higher refresh rate.
Season Two of the Trust Time Trial (T3) Contest has now begun. The fourth round is an accuracy round for multicopters, which requires contestants to fly a cube. The deadline is April 14th.249 members
183 members
693 members
24 members
51 members
Powered by
