About Ground Control Station User Experience
Hi Guys,
Could you give me some impressions about the GCS you use? If you can answer these questions for me, it will be very helpful:
- What is your drones’ usage?
- Which GCS do you use and why?
- What are the main features you use?
- What are the best and the worst experience using the Ground Control you had?
Thank you
  • Hey Beatriz, I'm an architect and I mainly use the drone from work to capture aerial views of land and buildings. The photographs serve as documentation material of the land before and after the construction phase. What do you use it for?
  • Hi,
    I use my drone for parties or vacation
    I love using my phone to print pictures, edit videos or pics or to post them directly
    I never had worst experiences with ground control
    Regards, hope this was helpful.
  • You must check out FlytGCS solution for your needs. I think it matches your requirements. It can help you connect your drone over 4G/LTE with ease and you can fly autonomously from anywhere. You can try FlytGCS for free
    The other option is UGCS too.
  • we use software to make the plan on app.
    http://www.dronefromchina.com/academy/route-planning-in-the-app-sof...
    Route planning in the APP software
    Sprayer Drone, Drone Agriculture Sprayer, Agriculture UAV Crop Dusters, Agriculture UAV Sprayers, Pesticide Spraying Drone, Fumigation Drone, Crop Sp…
  • I think you can leave your email and I can give you another choice.
    Jakob Schmidt said:
    Drone: Fixed wing mapping/surveying
    GCS: Mission Planner. Why? lack of other options?
    Features: Setup, planning and flight monitoring, post-flight review.
    Flight planning interface is not very intuitive, but works ok once you get used to it.
    Worst is the log-analyzer, "hidden tools" (Ctrl F).
    Set-up can be complicated, but it's more an indication of the complexity of the flight controller (Pixhawk) than the software.
    Hi Guys, Could you give me some impressions about the GCS you use? If you can answer these questions for me, it will be very helpful: - What is you…
  • hello  Beatriz Palmeiro:
    you are very nice, i like you.
    Beatriz Palmeiro's Page
    Beatriz Palmeiro's Page on DIY Drones
  • 1 the ambient air temperature is not higher than +40 C, not less than -5 C. The average temperature within 24 hours should not be higher than +35 C. When it is over, the operation should be reduced according to the actual situation.
    2 indoor use, the use of the site at an altitude of no more than 2000m.
    3, the relative humidity of the surrounding air is not more than 50% at the highest temperature of +40 degrees C, and relatively large relative humidity is allowed at lower temperature. For example, +20 degree C is 90%. We should consider that the influence of condensation may happen occasionally due to the change of temperature.
    The inclination of the 4 installation and the vertical plane is not more than 5 degrees, and the whole set of cabinet columns is relatively flat (according to the GBJ232-82 standard).
    The 5 device should be installed in a place where there is no severe shock and shock as well as the undue corrosion of the electrical components.
    When 6 users have special requirements, they can negotiate with our company.
  • Hi,Beatriz. My drone is use for guiding the way and carry some small things from my here to you there XD. And of course I use it to take pictures from the air.
    I equipped my drones with a kind of LiDAR--CE30 from Benewake tech. It is test well. It help my drones detect the obstacle so it can avoid and fly more efficiently. If you like, I'm willing to recommend you to have a try.Here is the product link: http://www.benewake.com/en/ce30.html. And there are other products can help.
    So the drones are autobots, less rely on GCS. XD.
  • Hi; I see there's some activity going on on this post, so I'd like to share my experience.
    I do aerial surveys in the RGB, NIR, and Thermal bands to target various 'objects' (terrain, structures, PV panels, agriculture, etc.); most missions are flown in "photogrammetry" mode, which require dedicated and specific tools/parameters: to me Mission Planner is best option from this perspective, having almost unbeatable features (and a lot are still to be discovered  ;-).
    Another area where I find MP being top-notch is pre-arm checks, calibrations, auto-tune, and "parameter tweaking" in general.
    So my workflow is based on MP for flight planning; I then connect the UAV to it to check and arm; as a recent "upgrade" however, after testing QGC and Tower, I setup multiple GCSs' (which can be considered 'slaves' receiving telemetry data from the PC running MP, even though they can be actively used in controlling the drone) running those gs softwares - specifically, on my RC radio I have my cell phone running either of the two (or both, if I want to) to monitor flight times, battery voltage etc, and they also have a handy "pause" button.
    I want to thank all the Open Source, Ardupilot, this site, and connected devs: we're seeing something awesome, where even somebody like me can actually have and use an UAV, and try and experiment those new technologies, previously accessible only to a "small circle".
    Giovanni
  • 1) fly for fun, fixed wing, I used to be a hardware/software autopilot developer, now retired
    2) Mission Planner, because it does most of what I need
    3) I like and use many/most features.  I have the following suggestions:
    - FLIGHT DATA -> SERVOS - provide a slider to position the servo in any position between min and max
    - FLIGHT DATA -> ACTIONS - make the buttons larger and allow me to assign the action to the button, e.g. my landing sequence usually starts with waypoint 7.  So I would like a large button that does SET_WAYPOINT = 7.  Although I am fortunate in being able to fly outside my shop and the GCS is located just inside the door, it takes awhile for my eyes to adjust sufficiently to see the small buttons.  Ideally, the ACTIONS tab would have its own window like the HUD.
DIY Robocars via Twitter
RT @knightsautoteam: Hi @diyrobocars, we are Orlando's first Autonomous racing club and would love your support. We are hosting our first K…
Friday
RT @Heavy02011: #VirtualRaceLeague: @DIYRobocars Race #14 - #ParkingLotNerds join us January 15th for #AutonomousRacing #RoboRace ⁦@DAVGtec…
Jan 16
RT @chr1sa: And after that came our races, 50 in all. This battle between these two Russians was the best we've ever seen -- incredible fig…
Jan 16
RT @chr1sa: Before our @DIYRobocars virtual race this weekend, we had a presentation from the team that won the Indy Autonomous Challenge i…
Jan 16
DIY Drones via Twitter
Dec 12, 2021
Dec 12, 2021
RT @chr1sa: Just a week to go before our next @DIYRobocars race at @circuitlaunch, complete with famous Brazilian BBQ. It's free, fun for k…
Dec 4, 2021
How to use the new @donkey_car graphical UI to edit driving data for better training https://www.youtube.com/watch?v=J5-zHNeNebQ
Nov 28, 2021
RT @SmallpixelCar: Wrote a program to find the light positions at @circuitlaunch. Here is the hypothesis of the light locations updating ba…
Nov 26, 2021
RT @SmallpixelCar: Broke my @HokuyoUsa Lidar today. Luckily the non-cone localization, based on @a1k0n LightSLAM idea, works. It will help…
Nov 25, 2021
@gclue_akira CC @NVIDIAEmbedded
Nov 23, 2021
RT @luxonis: OAK-D PoE Autonomous Vehicle (Courtesy of zonyl in our Discord: https://discord.gg/EPsZHkg9Nx) https://t.co/PNDewvJdrb
Nov 23, 2021
RT @f1tenth: It is getting dark and rainy on the F1TENTH racetrack in the @LGSVLSimulator. Testing out the new flood lights for the racetra…
Nov 23, 2021
RT @JoeSpeeds: Live Now! Alex of @IndyAChallenge winning @TU_Muenchen team talking about their racing strategy and open source @OpenRobotic…
Nov 20, 2021
RT @DAVGtech: Live NOW! Alexander Wischnewski of Indy Autonomous Challenge winning TUM team talking racing @diyrobocars @Heavy02011 @Ottawa…
Nov 20, 2021
Incredible training performance with Donkeycar https://www.youtube.com/watch?v=9yy7ASttw04
Nov 9, 2021
