AC 3.1.1 crash need help in analysis
Hi all,
i had a crash today with my quad with the following components:
3dr APM 2.5 + 3dr GPS with external MAG + 433mhz telemtrie
Futaba R617S
4 x Rctimer HP4108-480 KV with rctimer 40A opto ESC
BEC standalone.
90A voltage and current sensor
while doing some agressiv yaw tests the copter flipped (i did stop the yaw input)
log is attached i will upload the video in a few minutes,
Thomas
2014-02-17 14-28.log
  • Yep, your ThrOut go very far down - this reminds me of aomething I reported while doing badass testing, I even predicted a crash :)
    Unless your motors have a pretty high idle speed set, one or more probaply stalled when APM commanded the low throttle:
    https://github.com/diydrones/ardupilot/issues/836
    • Thanks Andre,
      any way to prevent this ? i'm flying 15 x 5,5 props@5S very  efficient setup :-)
      maybe higher ThrMin ?
      thanks
      Thomas
      • yes, higher minimum throttle/idle throttle will fix it - do plenty testing on ground .
  • http://youtu.be/CBYAfuONFK8
