  • I also need this. What happened?
    • I was just looking into this and here is what i found:
      my versions: APM V3.1.4, MP is current.
      the command is now only in the full parameter list.
      "LED Mode"  default is 9.
      Explanation is here: LED modes
      I have not confirmed it works yet, but it is a place to start.
      • I can confirm that adjusting the LED's through the full parameter list works.
        Remember that the full parameter list is not min/max checked and I discovered that anything over I think 130 wouldnt work/update properly
        When doin trial and error tests to determine the binary code for my particular bit mask I found that if you change the decimal, click write settings and the LEDs do not change you will need to disconnect, disconnect power then reconnect to update the parameter with a new value. This only happened after changing the LED mode value 3 or 4 times in a row
  • I would also like to know that. Looking at the source code from 3.0 vs 3.1 led_mode disappears. Why?
    Thank you
  • anyone ?
