Shaun Bell > leonardthallSeptember 24, 2015 at 7:56am
Thanks for looking at those logs! The tune between those was very similar to the last one, but the pitch and roll didn't track as well. Think I'll use the yaw from the first tune though. It's a little abrupt on the last tuning, not so good for video work : )
Hey guys I can't get AutoTune to work withthese SimonK ESC at all. Testing without batteries plugged to computer via USB confirms AutoTune mode engages. The copter does not start twitching or calibrating itself when testing with batteries.
I have some trim settings set, will that interrupt the process from starting?
I tried to do autotune, but battery was not enough to complete even one axis (~11 minutes). Is there a way to continue autotune after battery change?
Actually, I failed to do normal manual PID tuning procedure too, as even with P=0.22 on pitch and roll I still have no oscillations and as I understand going for bigger values is not recommended.
leonardthall > Michael KachalinAugust 19, 2015 at 2:17am
Hi Michael,
If you send me your log I should be able to give you better starting parameters based on your tune.
To do a manual tune, increase Rate_D until you get some oscillation, then back it off by 25%. Do the same for Rate_P. It doesn't matter how high it goes, your setup may need it.
There should be limitations on every value, as power of the system is not infinite, so you think, they are more than recommended 0.25 for P? With my current settings hexa is quite responsive on pitch and roll but very lazy on yaw. Haven't tuned I for any of the axes yet.
Hi Shaun,
Definatly use the last tune for Yaw!!!!
Then just back the ATC_ACCEL_YAW back to get the feel you want.
Here's the dropbox links to the autotune logs:
Autotune 01 https://www.dropbox.com/s/sr3cuukrpivg1aw/autotune01.bin?dl=0
Autotune 03 https://www.dropbox.com/s/j6u3gzk2hf6pba6/autotune03.bin?dl=0
Attached are the short log files of the X8 flying after each autotune.
Flight01.bin
Flight03.bin
Video isn't possible to see now, says that is private; It's only my issue?
Hey guys I can't get AutoTune to work with these SimonK ESC at all. Testing without batteries plugged to computer via USB confirms AutoTune mode engages. The copter does not start twitching or calibrating itself when testing with batteries.
arducopter will interpret the trims as the pilot trying to take control and pause autotune.
Sounds like you need to level the copter.
Great, I suspected as much. Will save trim and reset on tx and retry. Much thanks.
Thank you,
Michael
Hi Michael,
Your log should tell me much more.
Hi Leonard,
Thank you.
Here are three logs from my attempt to autotune:
https://www.dropbox.com/s/e78f4kdnwrp670e/73.BIN?dl=0 attempt to autotune all axes
https://www.dropbox.com/s/wxbuipf98at8ai1/74.BIN?dl=0 roll (or pitch?) only
https://www.dropbox.com/s/qijv8tmy455lclf/75.BIN?dl=0 yaw only
Log below is my manual tuning in Alt Hold mode.
https://www.dropbox.com/s/1dfgha9q9ur9l17/79.BIN?dl=0
