Hi.
I have a problem after updating AC to 3.2.1 from 3.1.5.
When in Loiter, the the speed of the motors rev up and down/pulsate quite rapidly. This was working fine when I was using previous versions of arducopter.
I have downloaded the logs, and have looked into accX, accY and accZ. These seems to be inside the range specified in the wiki at arducopter. (Log_vibrations.bin)
Please have a look at the Log.bin, and note the difference between ThrIn and ThrOut when I'm in Loiter mode.
Anyone having any idea what the problem may be?
Looking at the code it has changed A LOT between 3.2 and 3.2.1 - it's basically a bulk integration of the 3.3 sensor code as far as I can tell. I am not at all convinced that the default handling is right in the new code, but its changed so much that a direct comparison is very difficult. I'm hoping someone who understands (@Tridge? it was his change) can make an assertion one way or another.
https://harkness3d.wordpress.com/2015/03/23/fixing-the-height-drift...
Perhaps my question got lost among all the other postings. In short: By tuning down Throttle Rate and Throttle Accel I got rid of the pulsing, but Alt Hold behavior is still bad. What should I tune next to improve Alt Hold? Screenshots, log and quad specs here.
As I wrote here before for my copter (Y6b with large props) it makes a big difference in alt hold performance wether I use a canopy or not - perhaps props influencing baro in pixhawk.
Especially the dramatic drop after braking from fast forward flight is almost gone.
Do you use some kind of canopy?
:o :o :o ; some weeks ago I bougth a salad and comes with a light weight canopy so I store it but not use yet, my Original build had a canopy with open slots for pressure but I removed because It's 100grs weight, for your comment but not conveinced I try with the salad canopy and the cuad flyes with a rock solid altitude hold :))), I test agressive flying side to side and perfect :O all the life of this cuad loose altitude when I fly agressively side to side, specially for left, I try many things and nothing or little changes including the first canopy; I complete surprise, today little wind, I'm going to try again in windy day. MANY THANK's for your comment Hubertus.
Here my improvised canopy photo
Another surprise when I read logs, horrible vibs near limits, I never can fly with this vibs levels, my papers are burning :O (this copter is in rebuilding process waiting an ext compass and more adecuate props) ; I'm going to do more test to confirm if this is realy true on windy days and share here.
yeah, nobody read manuals this days...
Perhaps part of reply is here from instructions http://copter.ardupilot.com/wiki/altholdmode/
There are no real tuning hints in the wiki. Randy's suggestions (No. 3 and 4) were the first explicit ones I found. And they worked fine regarding the pulsing motors. But I have no idea what to do to prevent the quad changing altitude that dramatically (see screenshots above).
