AC3.2.1 APM 2.5 Throttle pulsates in Loiter
Hi.
I have a problem after updating AC to 3.2.1 from 3.1.5.
When in Loiter, the the speed of the motors rev up and down/pulsate quite rapidly. This was working fine when I was using previous versions of arducopter.
I have downloaded the logs, and have looked into accX, accY and accZ. These seems to be inside the range specified in the wiki at arducopter. (Log_vibrations.bin)
Please have a look at the Log.bin, and note the difference between ThrIn and ThrOut when I'm in Loiter mode.
Anyone having any idea what the problem may be?
Log.bin
Log_Vibration.bin
            • What I have'nt tell is that  If I let go my stick of roll very gently , it would not overshot ,even after a high speed flight. I guess the reason for that if my frame is too light. After a hight speed flight the vehicle would climb normally , the althold controller have to reduce the THR_OUT to keep the vehicle from climbing .Once the THR_OUT been reduced ,the stb controller can't hold the fram stabile ,so it overshot !
              • There is common manual what you should do, to get drone in the air.
                It is on apm wiki, and if you follow all the instructions there it will get better.
                I know it could seem, that it flies OK and it is awfully boring to do everything from scratch, but for now there is no other option.
                I like to skip some steps myself and I should admit, there is no easier way than through manual.
                1. Wizard.
                2. Autotune.
                3. PID extra tuning if needed.
                Right now you are trying to tune advanced parameter, when basic parameters are not in good shape. It's a good way to have headache.
            • I mean no problem WITH althold,it just roll and pitch got overshoot. the althold is good!
              my setup :HEXA frame size 680mm  F4006 KV680   30A blheli   1238   4S5000   2400g
              I have'nt done autotune.  my pid is so large now,  rate_p  =0.25  rate_i=0.25  rate_d =0.024 , I am not sure autotune can success or necessary,since  the loiter mode is very good ,soild  in the air.
              the only problem is overshot after high speed flight ,if I let go roll stick quickly.
              I have tried lower rate_p to 0.185 ,the overshot get bad,almost to 70 degree,So I don't know, should I keep raise my rate_p ,  since it is so large already now!
              • Just try autotune. It will do everything as it needs to be.
                Handtuning PID is like searching for a cat in dark room by smell :)
                My PIDs were WAY too far from default values.
                But still I recommend extreme caution, 700mm quad is no small thing.
        • Still consistent with my theory since the change was between 3.2. and 3.2.1  :)
          • Yes, but 3.2 has a lot of useful features that 3.1.5 does not have.
  • /!\ Message for Dvelopers, please respond. /!\
    Obi Van Kenobi, you are our only hope.
    Can we use complimentary filter as it is shown in this artice?
    It might not require as much resources and speed as EKF, but it could give fresh breath to APM 2.x platform.
    Comments appreciated.
    Reading a IMU Without Kalman: The Complementary Filter | Pieter-Jan.com
  • Hello All,
    I am having this exact problem in Ac3.1.5 with APM 2.5. Alt Hold was working fine in 3.2.1 (or maybe not this bad) but when I downgraded I started having issues. I have a discussion page in the following link with more info and flight logs (http://diydrones.com/group/arducopterusergroup/forum/topics/capston...).
    As you can see from the image below and the log (named: 2015-04-21 20-18-29.log) attached, although the APM knows that the altitude is increasing and the error between desired alt and barAlt is increasing, it doesn't compensate.
    3701986734?profile=original
    red (barAlt) green (desired Alt)
    Thanks for helping!
  • I wonder if any of the developers had thought of creating a fork?  Let the APM side go separate path?  The current code is too large to fit onto an APM, but it has a lot of code for the Pixhawk that had nothing to do with the APM.  So maybe someone can go in and remove the Pixhawk specific code to get it back to a size that would fit the APM and allow the APM to still enjoy the new features?
    • It's not that simple. The reason 3.3 is pixhawk specific is because it uses EKF only for navigation - which is too slow to run on an APM. So pulling in features would require that you avoid EKF stuff - and that permeates the 3.3 codebase. Better to fork 3.2.1 and fix specific bugs as they come up. Like this one :)
DIY Robocars via Twitter
RT @knightsautoteam: Hi @diyrobocars, we are Orlando's first Autonomous racing club and would love your support. We are hosting our first K…
Friday
RT @Heavy02011: #VirtualRaceLeague: @DIYRobocars Race #14 - #ParkingLotNerds join us January 15th for #AutonomousRacing #RoboRace ⁦@DAVGtec…
Jan 16
RT @chr1sa: And after that came our races, 50 in all. This battle between these two Russians was the best we've ever seen -- incredible fig…
Jan 16
RT @chr1sa: Before our @DIYRobocars virtual race this weekend, we had a presentation from the team that won the Indy Autonomous Challenge i…
Jan 16
DIY Drones via Twitter
Dec 12, 2021
Dec 12, 2021
RT @chr1sa: Just a week to go before our next @DIYRobocars race at @circuitlaunch, complete with famous Brazilian BBQ. It's free, fun for k…
Dec 4, 2021
How to use the new @donkey_car graphical UI to edit driving data for better training https://www.youtube.com/watch?v=J5-zHNeNebQ
Nov 28, 2021
RT @SmallpixelCar: Wrote a program to find the light positions at @circuitlaunch. Here is the hypothesis of the light locations updating ba…
Nov 26, 2021
RT @SmallpixelCar: Broke my @HokuyoUsa Lidar today. Luckily the non-cone localization, based on @a1k0n LightSLAM idea, works. It will help…
Nov 25, 2021
@gclue_akira CC @NVIDIAEmbedded
Nov 23, 2021
RT @luxonis: OAK-D PoE Autonomous Vehicle (Courtesy of zonyl in our Discord: https://discord.gg/EPsZHkg9Nx) https://t.co/PNDewvJdrb
Nov 23, 2021
RT @f1tenth: It is getting dark and rainy on the F1TENTH racetrack in the @LGSVLSimulator. Testing out the new flood lights for the racetra…
Nov 23, 2021
RT @JoeSpeeds: Live Now! Alex of @IndyAChallenge winning @TU_Muenchen team talking about their racing strategy and open source @OpenRobotic…
Nov 20, 2021
RT @DAVGtech: Live NOW! Alexander Wischnewski of Indy Autonomous Challenge winning TUM team talking racing @diyrobocars @Heavy02011 @Ottawa…
Nov 20, 2021
Incredible training performance with Donkeycar https://www.youtube.com/watch?v=9yy7ASttw04
Nov 9, 2021
