@Daniel Bowles Can you please explain the steps as to how to interface Adafruit Ultimate GPs with Pixhawk flight controller,as I'm completely new in this field
could you set up adafruit ultimate gps with pixhawk?
Daniel Bowles > Tomi PiriyevDecember 26, 2014 at 10:16am
Yes, I have it working on my TBS Discover w/pixhawk. I just set it up as 5Hz updates @ 38400 baud. Most have recommended that the 3DR setup is better, but it does work.
Tomi Piriyev > Daniel BowlesDecember 26, 2014 at 11:15am
ho w is the performance of adafruit gps on piwhawk?
Daniel Bowles > Tomi PiriyevJanuary 6, 2015 at 10:55pm
I generally get a .98 gpshdop with 8-9 sats, and 1 gpshdop with 7 sats. I would have to get the 3DR module and use it for a while to get a real good comparison though.
Well, It usually happens when I give up and post a question I figure it out. So it appears to be working. Just had to use the MiniGPS tool and set it to 5Hz updates and 38400 baud rate. The true test will come at flight time.
Hey,
Best advice is get a ublox. They are much better
Cool Thanks for the advice. That is probably what I will do when I can.
Daniel
