Adding extra functions to MinimOSD
I have started to add functions to MinimOsd code.
At first i did it for myself only. Added many functions i thought i need. Then opened this thread.
after a while, Pedro and later Miguel came, and things started to happen fast. :D
They have optimised the code and added even more things to it.
They have worked hard on CT, and it became a great tool!
Thank you Bough! :)
By now MinimOSD-Extra got a pretty advanced OSD.
Here it is in action:
Added:
- Changeable unit measurement (US, metric)
- Airspeed
- Home alt
- Battery Percent
- Battery used mah
- Current Draw
- Time From Startup (cleared at takeoff to show exact flight time)
- OSD Menu
- Variometer
- Wind horizontal speed and direction, and also the average wind speed of the last few minutes.
- OSD on/off
- Switchable secound screen
- WP distance
- WP heading
- Crosstrack error
- Warning messages for Lost GPS fix, Stall, Overspeed, battery volt, battery Percent, RSSI
- Efficiency, glide distance & thermic notifier. 3 in one panel
- OSD Brightness
- HAM Call Sign
- After flight summary
- Trip distance
- Temperature
- Smoothened horizon
- Real heading
- RSSI
- Vertical speed
This functions can be turned on and off, and placed on different screens now, by the Config. tool.
Also RSSI, switching mode and channel and unit measurement, Stall speed warning, Overspeed warning, Battery warning volt, Battery percent warning, RSSI warning,  can be set in new Config Tool.
We built in a new way of setting video standards. Now OSD does not guessing anymore :). You can set it fixed from CT. It is in "Video Mode" menu.
Here is how it looks: (This video is a bit outdated, sorry. I will make a new one soon.)
The MinimOSD-Extra project is here: Link
This project is the developing version of the official Arducam OSD located here: Link
The latest stable version is: 2.2
The latest version can be downloaded from here: MinimOSD-Extra R800
Username: MinimOSD_Extra
Password: Top_Secret
CT is included. (The FW for Plane, Copter, Character upload and the character file is in the "FW & Char" directory inside CT directory)
We are sharing it to see videos you make using it! :)
Enjoy
              • Hello Mathieu
                I solved the problem now !!!
                In practice:
                if you are using - APM Planner SR0 parameters are not updated, so that the MinimOSD not working properly, and does not show the battery voltage
                while using MissionPlanner (I used the latest version 1.3.9) the parameters SR0 update finally works perfectly and MinimOSD !!
                This is the link from where to download MissionPlanner
                http://firmware.diydrones.com/Tools/MissionPlanner/
  • Hi,
    I am using MinimOSD-Extra_Copter_Pre-release_2.4_r726 and having an issue of MinimOSD not reporting the correctly the altitude. The barometer and GPS are working fine and the true altitude is being recorded properly as it can be seen in the APM datalogs, but, for some reason, at certain point during the flight looks like the displayed altitude in MinimOSD is reset to zero. Check the following video:
    MinimOSD Problem
    Is anyone having any similar issue?
    • I have the same issue, I know this post is old but did you figure out a solution?
  • More great news in the latest APM beta firmware, Terrain Following is here. I tested it and it works very well. What does this mean for MinimOSD-Extra? It means we can now know how high we are above the ground! Like a poor man's radio altimeter we can now see the AGL altitude. This is seen on the status page as tur_curalt. The terrain altitude is tur_alt.
    Here is a message to you guys from Tridge:
    It would be good if the OSD also displayed TERRAIN_REPORT.current_height, so OSD users know their terrain height. That value is available even if you are not following the terrain.
    Cheers, Tridge
    This applies to copters and planes.
    • 100KM
      But this only works if you have a telemetry link with a internet connected ground station? Off topic, but I was wondering what would happen if the internet drops on the ground station. Would that risk a crash?
  • hi to all..
    My rx pin in minim osd not work...I made mistake and connect 6v in the rx pin....now the osd unable to configure and not receive the mavlink data...it's possibel to change in the code and use another free pin for rx??? I test upload firmware trought isp pins and works...
    Any help please!!!
    Thanks to all
    • Hi Luis,
      I believe it's not possible to route serial input through another pin as ATMEGA328p as only one uart port :(
      You may try to replace the atmega chip but that's a tricky task.
      Miguel
      • Ok...Thank you Miguel.
        • basically fried, did the same thing before, it probably will take code, as mine would however it would just show a black screen, fried mega chip
Aug 25
