  • If I balance it on the static point, won't that mean it will not be level in flight because planes require a certain angle to fly at?
  • Planes don't fly level though, they fly at a certain angle to remain level.
  • How are you suppose to balance it with blowing all the time.
  • No.  I am trying to get an autopilot to control it.  The control system from the autopilot needs its constants adjusted so the plane stays balanced from what I understand. How  are you suppose to figure out the constants needed.  When I tried flying it on autopilot it did an angled crash into the ground.
  • Your question is vague. Is your fixed wing aircraft physically unbalanced? Does it fly correctly in the manual mode?
