No. I am trying to get an autopilot to control it. The control system from the autopilot needs its constants adjusted so the plane stays balanced from what I understand. How are you suppose to figure out the constants needed. When I tried flying it on autopilot it did an angled crash into the ground.
If I balance it on the static point, won't that mean it will not be level in flight because planes require a certain angle to fly at?
Planes don't fly level though, they fly at a certain angle to remain level.
How are you suppose to balance it with blowing all the time.
Your question is vague. Is your fixed wing aircraft physically unbalanced? Does it fly correctly in the manual mode?
