Advanced Config Airspeed Ratio
Anyone able to explain this line from Advanced Configuration Settings?
"Adjust AIRSPEED_RATIO in small
increments to calibrate the airspeed
sensor relative to your GPS."
I would like to better understand the relationship between
GPS and Pitot inputs regarding this line in the code
Joe
    Depending on the implementation of your pitot your going to get a valued that's incorrectly scaled. This value can be adjusted to fix that scaling.
    What you need to do is fly around and compare GPS speed to wind speed. It would help if there were no wind, but you could factor out the wind if you had accurate enough info.
    Jason
