aerial camera
hey guys, i was wondering if i should add a static camera under the wing or to make a pan/tilt cam .  if i do do a pan/tilt cam, then would it be automatic or controlled by r/c?
  • by automatic, i meant it randomly aims and randomly takes pictures
  • Admin
    yep , depends on what do you want to do with your camera . What do you mean by automatic? If you are going for aerial photography /survey type project , under the wing may do but if you want to do FPV also then pan /tilt using head tracking or by RC .
  • Don't you think you're best placed to make those choices? Setup depends so much on your goals!
