AGRICULTURE DRONE PROJECT
i want to build a agriculture drone.....the payload of the drone min:5kg.......max:10kg.....
My problems :
1. I realy dont know which is the most effecieng multirotor desiegn for a Agriculture drone... maby double sided quad or tricopter
2. I dont know what motors to use .. now i have researched ..but that also depends on my multirotor design
.And i  dont want to go expensive over here... .....any recomandations WELCOME
3. What amp ESC do i need to use .....
4. How big battery do i need to use? how many cells do i need ?.....maby 10000mah
5. WHAT SIZE PROPPELER  SHOULD I USE
The flight controler:
I think apm 2.X is going to be the best . cause its not that pricy.and i can plan flights thats the biggest advantage ...it can hover around in the field. infact i aldready have apm 2.5 with gps and power module ....
GUYS PLS HELP I REALY NEED TO KNOW THE 1,2 QUESTIONS ANY THING THAT CAN HELP ....WELCOME
  •  you can search some available motors in www.crazy-motor.com, they sell some agriculture spraying motors.
    thanks.
    Professional BLDC Drone Motors  manufacturer
    As best drone motors and BLDC Motor for Drone supplier. We Customize drone Brushless motor and  electric drone motors for your droneand UAV system
