Airframe Arms
Anyone have a semi detailed or an opinion on how the length of the Arms affects lift, thrust, etc.?
I would from a physics standpoint only assume that the longer the arms, the more surface area exposed for gravity to exert forces thus possibly decreasing thrust. I am in the air-frame design phase of my hexacopter; i've created arms about 600mm long, they seem to be long enough to clear a 200mm prop at a 45 degree angle. Do i want to shoot for longer , shorter ?
All suggestions welcome.
  • bigger =  better damping
  • I went with arms as short as a I could for my hexacopter while still allowing clearance for the props but not for reasons related to performance or handling but simply to have a smaller footprint when transporting it. Shorter is also lighter as you have said, also less wire which can add up to a lot of weight. Not sure how the length affects the handling but I'd think smaller is better because the mass of all the motors is closer to the center.
Aug 25
