I was maidening a mini H-quad with a Pixhawk running AC3.1. On my first hover in stabilize mode, it worked beautifully. It was hovering perfectly still without any trimming needed. About 4 minutes into the hover, with the quad at about 2 meters high, all the motors suddenly cut off, and the quad just fell to the ground. I have attached the Pixhawk log file and hope some knowledgeable kind soul can help me decipher what went wrong.
Thanks for any help rendered!
Staq
PS: The quad suffered no damage, only 2 broken props. Really wish to know what really happened up there. Dare not fly it at the moment.
oh, and the voltage drop is about ~35mV, insignificant.
you whole flight varied between 5.250 and 5.170 - well within limits. ending record of 5.173 is not a problem.
Most of Pixhawk works at 3,3V anyway. and it would be out-of spec around ~4.8 or less.
ok, I guess you still won't believe my conclusion, like before - but what you *actually* can see, it Chan3 drop proportionally to 4, because motor 3 is the opposite motor of 4.
Like I told you, you lost lift on 4, so the opposite motor *must* reduce power not to flip.
motor 1,2 ? - they rotate in same way, they only adjust yaw at the time, and are forced to reduction, unless Pixhawk planned to spin it wildly around...
Servo outputs are behind a polyfuse, so pixhawk would not reboot . but ESC's usually have their own working voltage.
Stop overthinking it, you had a ESC, sync, motor, propeller or propeller-mount problem. - thatt's it.
Pixhawk only logged until crash made it lose power or reboot. - the final few lines may have not been written or not in an cluster that got updated in FAT.
Just an idea.
Could it be a Hard Cut off by the own ESC due to low battery?
It sounds like ESC problem
I had the same problem and the only thing that I can suggest is to reload the Arudpilot to the autopilot.
I had exactly the same thing, except mine stopped at 11m high and the damage was fairly substantial, I still have no explanation but what I do have now is a lack of trust.
http://ardupilot.com/forum/viewtopic.php?f=25&t=8769
This is scary, Graham. I am also using Tiger motors, and all original 3DR components. But I am not even doing any flying, just hovering on the spot, and yet this happens. Sad. My faith is shaken now.
