Alt Hold
My stabilize works just fine and when i put it into Alt Hold it shoots off like a rocket.  The barometer is covered and the APM is on foam to knock out vibrations.  Anything else i am missing here?
  • T3
    There is also the new parameter for mid throttle point called THR_MID. It's default is 50% and it might need to be changed to where your copter's throttle point hovers at in stabilize mode. The THR_MID wouldn't make it shoot like a rocket. Normally it would change altitude slowly. I'd also check if your barometer is breathing. There is a CLI test called pressure to check the barometer.
  • The barometer is covered with what? If it's sealed it won't register change in pressure.
May 21
Azjeg liked Azjeg's profile
Apr 27
Benewake LiDAR liked Benewake LiDAR's profile
Apr 12
Gremsy liked Gremsy's profile
Mar 12
