Altitude Hold with Sonar
Hi, I have a problem with the sonar altitude hold. I am running AC2.0.20 with default pids and the quad is in stable mode and is rock steady, when I engage alt hold at about 10 ft it holds really well within 6-12 inches. I turn off alt hold, do a bit of flying and try alt hold again it holds really well but after I've done this routine a couple more times it will not hold at all it just keeps climbing steadily until I turn off Alt hold. I have checked the sonar in the CLI test mode and every thing seems OK. Has anyone else seen this behaviour? and can it be corrected by adjusting the PIDs?
  • My experience with sonar (as of 2.0.19) has been similiar. Initially, the default pids caused mine to sink. I began bringing P up from .35 to .45 and had much better luck - as I hit alt hold, it drops a half foot or so but the seems to hold altitude fairly well, but it makes me a little nervous.,  When I went past a P of .5 it would rise quickly.I still need to play with it, tho, as I am not really certain of any stability. In the past I had a sonar mounting problem (Was not down far enough) and it would act very flaky probably due to close reflection. Mounting it lower solved this problem.  I recently reloaded Ardupirate code to verify the hardware - it tracks altitude incredibly well- no change when you enter it and rarely more than an inch variance even over many surfaces.
