  • First, thanks to all for the amazing work done on this project!
    My question, can someone advise if there is a version of the software that provides data on the Armed/Disarmed state of the flight controller to the Taranis?
  • Hello!
    Firat, i have read through most of the 100+ pages but I find myself at a bit of a loss on "where to begin". Or rather I got confused when the branches/mods showed up in the thread. :)
    I get confused over some of e forks that seem based on Arduino Micro Pro in comparison to the original code.
    So, here are my situation.
    I have a APM 2.6 with 3DR Radio and Minimosd (Minimosd only has the APM TX connected)
    I have a Taranis X9D Plus with opentx-9xdp-v.2.0.9.2
    I have an X8R
    I have a teensy 3.1 lying about.
    Which branch etc is my best be for this? :)
    • Hello Jan,
      take this code from here!
      Works perfect for me!
      Or this one but here i got problems with the storm32 bgc.
      Both are for the Teensy 3.1 and working out of the box.
      • Hello!I Hope YOUNDO not mind another question.
        I grabbed the fmoopdogg package.
        Hex is loaded. And I see messages on the serial console.
        I have copied the files from ApmPositionDisplaynto to my Sd card. But I get nothing when log pressing menu.
        Now, I will assume I need to config something to match my model names or such. I tested a bit but could not find what I needed to do.
        Yes, I am a Taranis noob. :)
        My model is "01" with name "Storfot". What should I change on the SD?
        Thanks!
        • If you haven't already, you need to go into the SCRIPTS folder on the SD card and change the sub-folder "model_name" to "Storfot".
          • Hello!
            I redid "from scratch" and renamed the "model_name" folder.
            This time it worked.. .So. obviously i screwed up before :)
          • Tjat is one of the first things I tried. But, I must have messed something up then. Will try again tonight. Thanks for confirming :)
      • Hello!
        Thanks and appreciated!
        I will investigate that branch in the comin evenings. :)
        How could telemetry interfere with a Bgc?
        • Read here, page 87 in these Thread.
          • Thanks!
            That will not apply to me. But I do appreciate you making the distinction!
