Hi all,
I just bought an FrSky Taranis for my quad copter and needed to get the Mavlink data up on the Taranis LCD telemetry display. So here is my solution using a Teensy3.1 as a converter between MavLink and the S.Port on FrSky X8R.
See attached file below...
I was in the telemetry screen - Sensors down to sensor 7 and bumped something now it reads [0.0ft] Funny thing is sensor 29 is reading correctly. Any idea how to reset sensor? The reason I was in there looking was the altitude seems to fluctuate a LOT way out of sync with reality. I would think it's just a quirky baro but the alt reading on GCS reads correctly so not sure what going on with that. Thoughts?
Richard, yes, you said you were running OpenTx 2.1.9 and >AP3.3 so the files I compiled were for those versions. If you need the files for 2.2 at any point then please ask and I can compile those also inside your Google Drive.
Enjoy!
Man the lua script is awesome! I thought I was going to just have to deal with some quirks if I flew my plane but then I saw the 'Telemetry script configuration' all zi had to do was switch to plane ...SWEET!!!! All the flight mode call out correctly.. can change the units ... WOW!!! Way cool man I have to apologies about my offer obviously this is worthy of TWO blonds wink wink. LOL
Paul Atherton said:
I went back to 2.1.9... copied your sd card files you did on my google link and it works great!!!!! You da man Paul!!!!!! 2-3 days I've been pulling my hair I REALLY appreciate your efforts to get me sorted out!!!! Best thing also is I can see what you did to the sd card files can compare with what I [ I have a copy on my Mac of course ] to see where I went wrong!! I think I'll just enjoy it working on 2.1.9 for awhile before the 2.2 switch as I know that requires another sd card structure. But I'm happy !! I love the layout of the script it tells you all you need / want to know in a great layout. Just awesome. Thanks!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
RK
Paul Atherton said:
Thanks Gary I appreciate you helping me out!
Garry Kraemer said:
Opps I didn't see this until now... Thanks!!
Paul Atherton said:
Me again.. so I understand why when I connect my Taranis with the usb it shows up as two drives. One is the Taranis... one is the sd card. Got it. I updated my taranis to 2.2 I downloaded the sd file structure of 2.2v0006 as my Taranis informed me it expected when I power it up after installing the 2.2rc10 firmware. I tried in vain to copy over the correct scripts and sound files from your page but I am confused because the new sd file structure doesn't look the same as your page shows. In fact there isn't even a 'models' folder. Isn't that where my eepe files would go? But anyway I must have gotten some files out of place because whenI put it back in the TX it said I now have the wrong card.. SOB!!!!!! ha Driving me nuts! Here's another new editable google sd card file link. I swear by God if you edit that to work with 2.2 I will have a hot blonde in a bikini deliver to your door a case of the coldest beer you ever tasted!!! LOL https://drive.google.com/drive/folders/0B3MgBBZGOf88N3E5ZUlNOUU3blk
ps I have companion 2.2rc10 I used that to get the the firmware from here
http://www.open-tx.org/2017/01/27/opentx-2.2.0RC10 [ I didn't get rc11 at the time because at that time I was hoping my sd card would work ]
Richard, I am in the process of uploading the entire SD card content for your setup to your Google drive. The folders under the path you sent me, should be placed on your SD card after first deleting everything you have there at present. It may take another 20mins or so for drive on my Mac to finish the upload, so maybe look at this tomorrow to make sure all has finished copying.
Just to answer one of your previous questions: it is correct that you see two drives appear when you connect the Taranis to your Mac. The first folder is called Taranis - this is actually the EEPROM memory of the taranis, and used only by Companion for its connection to your Taranis when you upload/download settings. The second drive that appears is the SD card itself. You can rename this if you want.
Cheers, Paul
> Here is sort of a big picture. When I connect my Taranis to my computer via usb it shows up as two entities. Taranis and > Taranis2... is this normal?
Yes, do not mess with the EPROM or FIRMWARE on that 'mounted' device.
> On TARANIS it has the EPROM and FIRMWARE the other Taranis2 has the SD card contents with all the items copied > over . I copied my models to the models folder as well. And yet when I go to the telemetry page down to page1 it
> says there are no scripts.?? I don't understand why even with the SD card removed from the TX when turned on it still > shows all my models ??
The models you fly and modify are contained in the transmitter. Consider the files on the SDCard as your backups. If you modify a model in the Transmitter, make sure you backup the changes to the SDCard.
> Sorry I know a lot of my problem is my lack of knowledge about how the Taranis all works.. You just make the Lua code I > know. I'm just stuck don't know what to try next.
Make sure you have 'LUA' enabled in the FIRMWARE load you are running in the Taranis. The first page has 'LUA' and it MUST be checked and the firmware downloaded and loaded into the Taranis for LUA to
function.
HTH.
Garry
Richard Kennedy said:
It seems like I have something going on with my radio. In fact it acts exactly the same wether I have the sd card in the radio or not! That can't be right. BTW I added my models to the models folder after that screen dump showing the SD card.
