      • This not declared scope error occurs during compiling ain Arduino 1.0.5 r2, so it is not depends on the actual board you have but the selection from the board list. I choosed Arduino pro or pro mini that is failed in compiling (just in test, not in upload). I tried to copy into exaples as you recommended but error is the same.
        What board do you select?
        • 3702769452?profile=original
          • 1.0.5-r2
            • having the same problems as Bordacs
              • which? the:
                MavLink_FrSkySPort:145: error: 'Serial1' was not declared in this scope
                is caused by wrong Arduino IDE, use 1.0.5-r2.
                • I have 1.0.5 rc2  but serial1 was not defined in this scope.
                  What shall i download the pro mini compatible version? i may have a broken version. http://svn.mbr89.de wont let me download anything!
                  • Hi Paul,
                    I've been searching for days now but without any result.
                    Did you find a solution?
                    please let me know
  • I have it wired up exactly as described to my Pixhawk telemetry 2 port (I checked the pinout for the pixhawk telemetry port to make sure it was right). When I power it up the Teensy just blinks orange slowly. The only telemetry value I get on my Taranis is A1 which reports around 4.4 volts. Any idea why it isn't working? Do I need to change the baud rate for the telemetry port on my Pixhawk? It's set to 57600 right now. Thanks!
    • Check if TX pin on the PixHawk is connected to RX pin on the Teensy.
      I believe there's an option related to MinimOSD on Mission Planner to force transmitting telemetry.
      I don't have that issue because my Teensy is in Parallel with the Bluetooth dongle on port 2, and on port 1 I have the 433 Telemetry radio alone.
      • Oh wow, that was the problem. I had TX -> TX and RX -> RX. I switched them and now it's working fine. Thanks so much!
DIY Robocars via Twitter
Saturday
Saturday
Jun 16
Jun 13
Jun 13
Jun 13
Jun 7
Jun 7
May 28
May 15
May 14
May 13
May 13
May 11
May 8
May 8
