Hi
I was just looking around for 868 MHz 500mW radios when I stumbled upon this radio --> http://www.radiocontrolli.com/en/products/transceivers-module/modulo-transceiver-868mhz-high-power-version.html
As it is Si1000 based then the SiK firmware should run on it as well. It would be a great alternative for European guys looking for longer range while still taking advantage of the SiK firmware. It uses the RFX1010 amplifier.
What do you think, would these modules work as a drop in replacement to 3DR radios?
I am using CISECO XRF
In Oz land using 1 Watt module fully compatible APM 2.6 modems:
http://store.rfdesign.com.au/rfd-900-radio-modem/
Had no problem of link distance.. :-)
For those where Tx power output is limited to 500 mW the rfd-900 from rfdesign.com output power is programmable from whatever you want to 1 Watt! So no more selection of hardware depending upon output power.. You choose by programming what you want!
Just great!
Henri
I also meant to post this link for an alternative 'bare bones' radio for putting the 3DR firmware on (Thanks to Mike Smith for the heads up)
see http://www.freescale.com/webapp/sps/site/prod_summary.jsp?code=KW01
https://solarbotics.com/product/51774/ 915MHz 802.15.4 $35
https://solarbotics.com/product/51768/ 2.4GHz 802.15.4 $25
They also run embeded Python, so it should be possible to add the MavLink framing, and more importantly the injection of the MAVlink Radio packet for RSSI information
There's a whole family of devices see http://content.solarbotics.com/products/documentation/synapse_compa...
I use 3g mobile internet, what can beat that? :)
I use it for both telemetry and video.
I built myself boards for DNT900. Very nice radios with power upto 1W and have AES encryption as well.
http://www.rfm.com/products/spec_sheet.php?record=DNT900C
My board has:
-Input voltage range of 2S-6S (with switching mode power supply)
-3.3/5V UART (configurable)
-FTDI chip for USB
-The board switches between the two automatically
-Onboard RPSMA connector so that the DNT900 U.FL connector doesn't get ripped off in case of a crash.
RFM provides two firmware versions, i think one should be compatible with European regulations (860Mhz range).
Note that the module on top doesn't have all the components (didn't have enough components for two boards at the time the picture was taken, a few months ago).
If there is enough interest, i could do a small run of boards to get the cost down (with Surface mount components, ofcourse).
-Saad
