Hi ya'll,
The thread on my blog post is getting a little unmanageable.  How about we discuss test results here instead...
I'll also post release notes as new builds are out.  The device must support 'USB host mode' (most devices running android 3.1 or later are fine).  You'll need a 'OTG' adapter such as this
Please post feedback here or on the github issues site - the google play comments are not really useful yet.
3689504133?profile=original
3690988742?profile=original
Hi ya'll.  Please move further discussion of this app to a newly created group:
http://www.diydrones.com/groups/705844:Group:1132500?xg_source=msg_appr_group
Feel free to make new approprately titled discussion threads.
Future app releases will be announced only there.
  • Still trying to figgure out why USB host port doesn't work.
    Earl
    sent from class at UNM
    Kevin,
    Looking good. I had reported that the position was not updating on my device. I have found that using ECC on the radios causes this issue and have resolved it by turning ECC off on the 3DR modules.
    Thank you- good work so far! I hope you continue.
  • It works!!! With my arduflyer2.5 on tricopter.
    Connected immediately, but the actual tricopter icon is not in the right place its should be,
    I had a GPS fix.
    The waypoints showed correctly.
    I Didn't check if the modes changed in my OSD.
    Very good work!!! Well done!!!
  • We can't use bluetooth device on this apk....only USB host?what a pitty...because all device doesn t have host..
  • @ 1.0.11: Screen rotation works fine now. xoom/3g 4.0.x. Best c.
  • 1.0.11 no longer crashing on my TF700 when I rotate.  Good job.
  • AWESOME WORK
    it s a very good tool for everybody!
    i like it
    thanks at all developer team
  • Well done Kevin,
    Will test out tonight.
    You are going to get hammered with requests cause this has been a long time coming.
    Really appreciate you working on this :)
    DIY OTG adapter
    just connect pin 4 (on micro side to the GND)
    Update: 1/22/13 New alpha released - You can download a binary from github.  Or wait a few hours and it will be up on the play store.
    As always feedback is welcome...
    Recent release notes:
    # 1.0.11
    * Add a preferences screen
    * Make logging controllable by preferences
    * Make altitude to use for guided mode set by preferences
    * Fix crash when waking from sleep
    * Don't leave service running unless we must (to service the serial port) - saves battery
    * Show battery voltage on the status pop-up
    * When we download waypoints, don't blow away the icon for the plane (duh)
    # 0.1.6
    * First cut at showing waypoints (read only and not fully decoded)
    * Long press to enter guided mode to the place you clicked on the screen (quick hack, hardwired to 100m AGL) Real code will pop up a menu/dialog
