Annunciator Panel in APM
Hi, being familiar with annunciator panels in aircrafts, i'd like to see if we could implement something like that. For those who don't know what i'm talking about:
We could have things like flight modes (att.hold, alt.hold, rtl, manual...), low battery alarms, overtemp alarms, stall, overspeed, things like that.
I know most people are happy the way it is now, I just think it could be nice. If anyone would be willing to help me code something like that, i'd be happy. I can code basic things in C#, and i could make the annunciator panel (graphic) and put it in a matrix of some sort. It could also be another program that uses data sent out by the mission planner.
Let me know what you think
  • RCTimer have released a APM annunciator board for the APM
    2S - 6S and with four high bright LED's. Just what I've been waiting for :)
    Home > Multi-Rotors & Parts > Flight Control LINK
  • Could something like this be used with the right coding?
    jD-IOBoard v1.0, MCU controlled IO Board for driving LEDs, Relays, Servos
    R/C UAV and ArduCopter manufacturer and one stop shop. We make your FPV come true.
  • You could use the parallel port to run a handful of leds if you want an actual physical board.  But this isn't 1980, so you don't really need display lights constantly wasting screen space.  If you have a warning, just pop it up.
  • Could you use serial data out (similar to the antenna tracker idea) to drive a pololu rc servo driver to then drive a servo switch unit to turn on and off leds ?
    That's already implemented in voice alerts in the Mission Planner. In general, it's better to do these things audibly for UAVs, since you'll want to keep your eye on the plane and screens are hard to see in sunlight.
DIY Robocars via Twitter
Videos from the ICRA autonomous racing workshop are now available: https://linklab-uva.github.io/icra-autonomous-racing/
Thursday
RT @SmallpixelCar: Prepared race track for Warm Spring Raceways @wsraceways and looking forward to test my new car at RAMS RC @ramsaicar fa…
Jun 6
RT @f1tenth: Trying out some nasty blocking maneuvers 🏎️🤖 #f1tenth #autonomousracing https://t.co/nMTstsaogM
Jun 5
May 27
RT @araffin2: I will talk this Saturday from 18:00 to 19:00 Paris time for the @diyrobocars community about learning to race in hours using…
May 27
RT @a1k0n: Luckily the infeasible hairpin problem was easily reproducible in simulation and I could test the fix before bringing the car ba…
May 26
RT @a1k0n: Another problem was that I was over-constraining the car's allowed accelerations, so it didn't think it could turn as tight as i…
May 26
RT @a1k0n: Breaking the map up into two halves worked, but I had to be more careful about separating the inner track from outer. There's se…
May 26
RT @a1k0n: Here's a datalog for my fastest lap of the day. Lap timer is tiny window lower-left. https://t.co/myrlWWrKUY
May 26
May 26
RT @a1k0n: Here was my car's POV. Man this track is confusing in first-person! After the incident my camera was all scuffed up and I was af…
May 23
RT @circuitlaunch: Loved seeing so many familiar (masked) faces at Circuit Launch today for our first in person @diyrobocars in over a year…
May 22
RT @circuitlaunch: Last but not least, mystery guest @BostonDynamics Spot took to the track @diyrobocars He enjoyed the #brazilianbbq too 😂…
May 22
RT @SmallpixelCar: Today’s race @circuitlaunch for @diyrobocars with @a1k0n Was busy in the morning and did not get a chance to tune camera…
May 22
RT @a1k0n: This was epic. My car was barely working this morning, had to make a lot of changes and extremely dirty hacks. Post-race analysi…
May 22
DIY Robocars @ Circuit Launch, 3/7/2020 https://twitch.tv/diyrobocars
May 22
