Another problem
Can I ask for some more help.I have had some good flights. I have just changed from + configuration to X. Dip switch 1 is now up and I turned everything off to reboot. I'm in Stable mode and the stability works fine, the motors do the right things.....But, the transmitter controls are wrong, they are still in + configuration, ie pitch control changes the front and rear motors 3 and 4 ? Any idea's.
  • Okay, I see....
    Did you use the firmware from this page:
    http://code.google.com/p/arducopter/downloads/list
    (Its the standard Arducopter Software: Arducopter RC2)
    ___________________
    or from that page:
    http://code.google.com/p/ardupirates/downloads/list
    (This is the recommended firmware with more features.)
    Remember for the ArduPiratesNG code you have to use the online configuration tool before flashing on to your electronics: http://code.google.com/p/ardupirates/wiki/Online_Config
    this tool lets you save a file. Call it "config.h".
    Then save it inside the ArducopterNG folder inside the sketches folder. After downloading both Pirate-Files: ArduPiratesNG-libraries.zip and ArduPiratesNG-sketches.zip unpack both folders into the sketch folder and rename ArduPiratesNG-sketches -> ArduPiratesNG. Inside this folder save your config.h file.
    The online configurator will show you if you have to change any of the jumpers on your electronics.
    Kai
  • What firmware do you use?
    Adrucopter  or ArduPiratesNG ?
