Guys,
I wanted to dabble into setting up an antenna tracker. Got myself the ServoCity Tube servos, for Pan and Tilt. Assembled it all with a Polulu Maestro and got the interface working. Followed the article here :
http://vps.oborne.me/gcs/Tracker.html
Few things I couldnt figure out and would be glad if someone can point me in the correct direction:
-- Any way I can set a minimum radiius for the Antenna Tracking to start working ? Dont want the tracker to go round and round when I am flying close by or doing passes around me.
-- For the Tilt servo, I have a 180 degree servo travel. The article above says that the neutral should be set facing 45degrees .. In that case though I cannot utilize the full 180 degree travel . Can only get 90 at the most. So my question here is, can the tilt center be set to 0 degrees ie facing straight up and 90 tilt on either side ?
I think thats most of it for now . Would appreciate some help.
Thanks !
the next mp version will have beta support for a 180, 180 servo setup.
I actualy think this is less effecient however, as you have 2 crossover point, instead of just 1 with a 360 pan servo.
ie if you fly around yourself, the tracker needs to do a full 180 degree pan, for 2 points of the circle.
whereas a 360 degrees needs to do a single 360 pan at only 1 point.
I just bought from the pololu website. www.pololu.com
W/ credit card, shipped via Fedex got here real fast (I'm in Chile). Bought 4 of them to make it worth the shipping. They should have cheaper shipping rates, if you don't need express.
Do I have to have my quad connected before I can see any activity on the Pololu Maestro?
I followed the instructions listed in the the web page. Everything works fine with the Maestro control program, all configuration saved... (Power off and power back on, and I have the values that I pre-configured)
But I plug into Mission Planner, (without my quad connected) and no joy. It comes to initial settings, but doesn't move from there. If I adjust offset for instance. I set home position manually.
What am I missing?
