Antennas Gets Its Own Forum Section
Chris Anderson has added this forum section for all topics related to antennas and radio transmission.
This will be a great place to see which antenna systems work and which dont work so well. You might want to get as much distance as possible out of each flight or just have that extra margin of safety. Maybe your video isn't all that it could be. Antennas are a key element in your drone system and this is the place to share what you use, find out what others are using, bounce ideas around and find solutions.
  • been kinda slow on here, what are you working on geoffrey?
    attachmentNew.php?attachmentid=3795950&width=360
    This is a great link for a DIY Cloverleaf antenna build.  For optimum performance you'd use a cloverleaf on both the transmitter and receiver side.  Here's the Link: http://www.rcgroups.com/forums/showthread.php?t=1388264
    Build covers instructions for the following antenna frequencies: 910MHz, 1280MHz, 2.4GHz, 5.8GHz
    Here is a link to another build: http://rcexplorer.se/page14/CPantennas/CL/CL.html
  • has anyone used the 5.8 patch array? whould it be used on GS? what whould be the best combo. of air and ground?and I have 1280 he has 1290 will that work well or no? thanks
