Hi Guys,
As you can see on the picture, one component has burnt on the tx (at the bottom near ts330 writing). However I can always transmit the signal with the sound, but no image. And when the tx is on, the TV screen is going black without frying. I mean there is no BSOD.
Do you think guys, it's possible to fix it? If you have an idea I'm interested.
Alex
my also burned today, someone already tested this fix, can confirm if it works?
Beware of the fact that many of Chinese made stuff follow no color coding, for some funny reason they use Red as negative in my cases. Many of their wiring harness has wrong color wire used in polarity, so do not assume red to be positive.
Sometimes I see someone have repaired this boscam it's so good and I'm happy to ear that
Have a good day....
My boscam works always...
I been using my repaired one since last year with no issues, but I use them as relay for my ground stations
Hi, I have 2 Boscam 200mw Txs with same (burnt fuse!) problem. I followed the method suggested my LordGotham, but it then led to melting of 12V power cable coming from 3S Lipo. Fortunately the JST plug at battery end melted immediately and that disconnected the battery from Tx. Some melting is also seen at Tx end of the power cable.
Can anyone suggest me what did I do wrong? Here is the picture of my soldering and bypassing work done on one of the Txs. Now I am afraid to do the same on the other one! Please help...
But fortunately both my Tx got working again. Thanks to LordGotham for showing the technique.
If it's of any help now, this is what I've learned about this subject.
Referring to the image I attached.
L1 is an inductor (AKA 'choke') and is around 10uH and has a resistance of around 0.5ohms.
R1 is a 'link' resistor of close to 0ohms. Swapping the link resistor to the vacant pads marked with an arrow will connect the DC output to the 5V regulator of the TS330 (giving 5V for a CMOS camera).
D1 is a Schottky diode, probably about 1 Amp size.
C1 is a vacant pad for a filter capacitor if required.
I accidentally shorted my 12V output to ground and burned the L1 inductor too like you guys, hence I found this thread.
I replaced it with a same sized SMD inductor scavenged from an old defunct PC network card, a smaller L value but good enough for now (R value was lower than original too).
I added a 10uF 16V SMD capacitor on C1 pads for the hell of it too. R1 was still OK when measured.
Cheers,
Martin
Thanks!!
two cable
the red is for 12v for the camera
and the other cable is to repared the burst component
so i try mine is ok
but now there are no protection...... :o( be carrefull
mine work prefectly
i hope you understand me
Could you confirm the following is the right wiring? Thanks!
