  • FYI this is illegal for use in the USA - you would be creating RFI in the military TACAN band and definitely will get busted! I believe the fine is 10 grand!! -KI6OYR-
  • Yes, It works, however I am getting some crappy signal on most of my channels. I'm not blaming it on this system yet because I haven't done much troubleshooting to look into it. The merchant is very friendly, however don't expect much in the area of technical support.
  • Admin
    Yep, I have the same one from different outlet( nghobbies) which I got for little more( Tx has digital channel display), you link also has them but not as combo package, and I am not in US( you may require HAM lic), I have also not tried long range test but short range test , every things ok so far. Good luck
