Anyone using Pixhawk with Futaba RS617FS Rx?
I am trying to install my new Pixhawk and I have a couple of RS617FS receivers.
I decided to modify one of the receivers according to:
    https://pixhawk.ethz.ch/tutorials/receiver_sum_signal
At first I tried adding a servo cable and try not to mess with any of the outputs but it didn't seem to be working because I couldn't perform a radio calibration in the mission planner.
So I decided to do the same thing as in the document because it looks cleaner and why not? :)
I removed the resistor and soldered a cable from the same pin as it shows the link above and still can't run a radio calibration in the mission planner.
(I don't have an oscilloscope at this moment to confirm if it's working and sending what it's supposed to send.)
I anyone using a the same or a similar receiver?
Here are some pics to show you what I did... it looks fine to me and didn't have any problems when soldering.
In the last picture, I noticed the IC model from my Rx where I'm soldering the cable is not the same as the one from the link above... I wonder if the cable should go to another pin on this IC?
Any ideas?
Thank you.
  • Hey Tono
    I'm also trying to get a Futaba R617FS to work with the Pixhawk. I have modified the receiver to make the PPM signal on a channel by removing the resistor and adding the wire. I have used an oscilloscope to confirm that I get the PPM signal on the right channel. When I bind my transmitter (Futaba T6EX) with the receiver the green LED indicating that there is a connection, and I can control servos on the other channels that I did not change. When I connect the receiver to my Pixhawk on the RC input and trying to do the radio calibration, nothing happens at all. I have searched around the web without finding a solution. Did you got yours up and running? I'm waiting for receiving my Turnigy 9XR + Fr Sky 4 D4R-II. Hopefully this will solve my problem.
    Best regards
    Søren
    • Hey Søren,
      I did the same thing to my Futaba receiver, carefuly removed the resistor and added the wire as in the manual.
      It never worked. I just don't have an oscilloscope to confirm that it is working fine.
      So I bought a couple of these ones:
      http://www.alofthobbies.com/frsky-tfr4sb-fasst-sbus-receiver.html
      And they work like a charm... recommended.
      Tono
      Søren
DIY Robocars via Twitter
Sunday
Saturday
May 13
May 13
May 11
May 8
May 8
RT @SmallpixelCar: Test my car. RTK GPS worked great. Thanks @emlid for their support. https://t.co/EkQ6qmjmWR
May 8
DIY Drones via Twitter
RT @chr1sa: @kane That's @diydrones circa 2009. Still have a box of those Canon cameras that we used to strap into planes, just like this.…
May 3
RT @chr1sa: Our next @diyrobocars race is going to be outside at a real RC racetrack in Fremont on May 28. Fully autonomous racing, head-to…
Apr 30
RT @f1tenth: Our Spring 2022 F1TENTH course @PennEngineers is coming to an end with a head-to-head race as a big finale. So proud of our st…
Apr 26
RT @DanielChiaJH: I wrote a thing! Throughout the development of my @diyrobocars car I've been using @foxglovedev Studio to visualize and d…
Apr 23
RT @SmallpixelCar: My new car for high speed. Low body, everything ( @NVIDIAEmbedded Jetson Xavier NX, @emlid RTK GPS, IMC) under the deck…
Apr 23
Apr 21
RT @f1tenth: F1TENTH Race training setup @PennEngineers for our upcoming ICRA2022 @ieee_ras_icra competition. @OpenRoboticsOrg @IndyAChalle…
Apr 21
RT @fatcatFABLAB: Proud to be hosting a restarted DIY Robocars NYC Meetup April 26. Come by if you want to talk about and race self-driving…
Apr 17
