APM 2.5.2 isn't outputting a signal to servos
Hello,
I'm having trouble with my new APM board. I have it all working and set up with Mission Planner. I can see the transmitter signals being received in mission planner but when in manual mode the one servo I have attached to the output rail isn't doing a thing.
I have the JP1 jumper in place and when putting a multimeter across the +ve -ve I see a ~5v signal.
I have tried the servo on other outputs but see no movement there either.
When testing the APM with X Plane I see no outputs to the simulator either.
Can anyone help me out? I've uploaded a video that might explain things a little more clearly.
Update
With the aid of a multimeter I have figured out the issue. There is a problem on the board that is causing the voltage to drop to 3.8 volts on the output rail with the JP1 jumper attached regardless of input power source. When I measure the resistance from the positive input to output channel one pins with JP1 in place it is a lot higher that I would expect.
If I remove the JP1 jumper and power the output separately things work without issue. So it looks like a manufacturing issue. I am returning the board for replacement on Monday.
  • Admin
    @Mark,
    How are you powering the APM? Are you using a PM or what?
    What firmware version do you have loaded on the APM?
    What other components do you have attached to the APM? GPS, compass?
    TCIII ArduRover2 Developer
    Mark, can you post a picture of where you're plugging in the servo, can't see clearly on the video?
