APM 2.5 initial set up problem process
I have problem with my APM 2.5
When I connect it with USB to PM I can download some ardu plane  firmware with no problem, like 2.74.
 When go to Flight data screen and move the APM the HUD did not move.
 The wireless telemetria conection % goes from 0 to 100%
 I got an initial message Bad GPS health
 I am not able to calibrate the radio and  compass  from the initial set up menu
 On the other hand by terminal option I can
 Connect with no problem, I can calibrate the radio, I can read the mode flights switch change but I am not able to calibrate the compass or accelerometer.
When I do I got the following message
 “failed to boot MPU6000 5 times”
Panic: failed to boot MPU6000 5 times
The same message error when I want to level.
Could somebody give any help to see what I have to do?
Thank in advance
  • You might have a defective 3.3v voltage regulator. Can you measure the voltage pin of the L2C port? it should read 3.3 volt
