APM 2.5 Log help
Hi All,
I have been working with my apm for a while and i have never really been able to fly it with much success.
Here is where is am at:
Old version of 3.2 no issues  new version of 3.2 i get bad gyro health.
No problem i disabled the the pre-arm check and took it out to my back yard and hovered for a few seconds and them i started to playing with it. Out of nowhere it pitched down and darted it forward with out warning. I also feel like its hit and miss on the direction that i tell it to go. meaning 1 out off three times that i tell it to go left at least on time it will go right.
Could Be my remote or it could be the APM I dont know i do know that the pitch is jittery without moving.
I am trying to go through the logs, but i have no earthly idea if what i am looking is correct.
can anybody give me a hand?
regards,
Julio Jo
2015-01-04 20-26-10.tlog
  • upload .log from APM.
    Also; great problem solving when disabling pre-arm checks - why would anybody program such a annoying feature ? When a fuse blows at your home, you'd probaply use a big shunt instead to disable future fuse-problems :)
    • Andre,
      so i dont have .log i only have .tlog and the reason for it that CLI is no longer support in 3.2 that i use option 2 the telemetry logs that mission planner out does when wireless telemetry is connected.
      • i did post a log file but it a .tlog is that not the same?
      • if I understand you right, you cannot find it in log download ?  - and download it over telemetry or USB ?
        that's unfortunate - that would be the best chance for finding out what happened.
        • i was looking thru my logs and i i found some .log files. hope these are good
          regards
          2015-01-06 19-14-17 5.bin.log
          2015-01-06 18-57-04 4.bin.log
          https://storage.ning.com/topology/rest/1.0/file/get/3702774700?profile=original
          • 3702833211?profile=originalSomething have become loose/unbalanced during the flight, you got very bad vibrations midair. May be a part of a prop that fell off, a motor came loose, or something like that.  The vibrations are far more that what's supposed to be flyable.
            The problems start after line ~2650 where you do a fast throttle change  (which is not an excuse for something to fail)
            The graph scales are not here due to picture width restrictions, but the IMU.AccX,Y scale is -45...+45 !  ()
            • i wish i had the video for what happened. the thing darted forward about 5 yards and hit my fence. broke a two props and one of the arms.
              That was some great analysis.
              so in your opinion the Gyro and acc are in good working order?
              • during flight they seem fine - but no, the fact you disabled the prearmcheck does not indicate everything is in order, but not necessary critical.
                You should recalibrate both, and enable armingcheck to be sure.
                • i have calibrated several times and the pre-arm will not let me arm the quad do to a bad gyro health.
                  the voltage on the regulator is putting out the correct voltage. 3.27
                  • never seen a problem like that - unable to tell how critical it may, or may not be.
