APM 2.5 no GPS lock...
So I am having some issues with my APM. I was using it on a Bixler platform for a while, then I decided that I would attempt a multi rotor (T-Copter). The specs of what I bought are at the bottom. I am having troubles with GPS lock. When I first was flying the plane it worked very well GPS lock no problem. But now after switching to Arducopter I get no GPS lock at all, an I can't even get it to go back into Ardrupilot and get a GPS lock. The GPS does have power, the red light is a solid red. I know some say there is a update required for LEA-6H?
When in Ardrupilot I get the blinking blue light then a solid yellow light
When in Ardrucopter I get a solid red light then when armed I get the flashing lights.
No Idea if any of this helps but this is what I get when I go into terminal and test the GPS
BR-APMPWRKTAPM 2.5+ Assembled Set (Top entry)
[GPS Module:uBlox LEA-6H GPS module]
[Power Module Options:XT60 connector]
1$229.99$229.99
^ AC-0005-01-APM25Ardupilot Mega 2.5 Case, Top entry1$0.00$0.00
^ BR-ArduPilotMega-05APM 2.5 ArduPilot Mega 2.5 Fully Assembled -Top entry-1$0.00$0.00
^ CA-0001-06EM-406/uBlox/MTK Adapter Cable 10 cm1$0.00$0.00
^ CA-0001-33DF13 6 Position Connector 15 cm1$0.00$0.00
^ KT-APM25-CableTelemetry adapter cable for APM 2.5 (Radio, OSD)1$0.00$0.00
^ PR-0001-133x08 Pin Header2$0.00$0.00
^ PR-0001-143x14 Pin Header1$0.00$0.00
^ PR-0001-221x02 Pin Header (H=4mm)1$0.00$0.00
^ PR-0001-232x03 Pin Header (H=4mm)1$0.00$0.00
^ PR-0001-262.00 Shunts1$0.00$0.00
^ USBA-MICROUSBMicro USB Cable1$0.00$0.00
^ BR-3DRLEA-63DR GPS uBlox LEA-61$0.00$0.00
^ BR-APMPWRAPM Power Module with XT60 Connectors1$0.00
$0.00
  • The cheap 3DR GPS as a dud. I have 2 and they were a waste of money. APM is a brick without a reliable GPS. Just finding stat lock is only the start of the problems with these.
    You have most likely worked this out by now but it may help others to know this.
