APM 2.5 radio calibration dont works.
Hello!
I'm realizing a APM 2.5 driven hexacopter. I have the original APM 2.5 and a Graupner 4 channel receiver.
After connecting the APM 2.5 via USB to the PC and starting the calibration in Configuration fron the Mission Planner, I get no response at the channel calibration.
The APM should be powered properly.
I dont have any clue how to solve this, but I am really stressed, because the hexacopter should fly within 2 month a a presentation.
Here are some pics:
3691008889?profile=original
3691009204?profile=original
Do you see any problems with the wiring.
Thanks in advance
Marcel
  • I have the exact same problem. Has someone found a solution?
    Thank you.
  • This is the same problem im having every thing els seems to work it just refuses to alow a radio calabration I see no input from my radio i know it is the board i tried with another apm i have and all is correct i can calabrate the radio fine
  • I'm having the same problem. Tried calibrating using CLI with no success. Testing in CLI also gives no response. I have other sensor readings though.
    Did you fix this problem?
