Has anyone successfully used the APM2.5 (or other APM) with the cheaper NEO-6M ublox gps ?
Did you need any modifications to the source code ?
Thx !
Thx !
APM 2.5 with NEO-6M ublox gps
We have this board but not the connectors - could some knid person please indicate exactly what connection cable is required to join the two
I am about the put my f****** foot through this frame. Ive tried everytyhing now and this has been ongoing for over 4 months now
Same issue with Naza v2
I will try again tomorrow any suggestion to check to find out what could be the problem?
Any thought about what could be the problem?
what the heck kinda gps do you have?
thats not normal
also gps only uses 4 wires
nah an the neo 6 is great, i use it under two floors and i still get a 6 sat 3d lock.
You should bbuy some of those white to white plugs and plug the gps and telemetry into their dedicated ports
Ha, I remember I had this too when I first tried it on the bench. Panicing because no fix. Inside you only get a fix sometimes and even then after multiple minutes (10-20).
Put the whole thing outside, give it a clear view of the sky and let it sit there for 10 min. Then check if you get a fix.
These crius NEO6 gps's are cheap but they are not very quick to get a 3D fix. Certainly not if their onboard battery is dead or if they haven't had a fix recently in that location.
i have re-flashed the gps few times with different firmwares but still i got the same issue could be that i need a different firmware for the tele? is there is a different one,
i'm really frustrated about this :(
