APM 2.6 acting strange
This is the third quad I have scratch built with the apm board,I am very familiar with how this board works and what is needed to help make this a perfect machine,But this newest copter I am building is being nothing but trouble,It still has compass interference even though the compass is more than 15cm away from everything on a mast,It is very very sluggish even though I have the parameters set as high as they can go to counteract the sluggishnessThis quad frame is quite larger than any I have built and I'm starting to think this might have something to do with it,This quad have a lot of flew to the arms when throttling up, would this have any effect over the sluggishness?Also the quad will very pitch one way very well but when I go to pitch the opposite way it is very slow and throws the copter off sometimes, why is this happening?I'm buying longer gps cables so I can mount the gps even further away from the frame, do you think this will help with the compass interference?Also I'm running 2.9 copter as this is the firmware update I have had the least troubles with, every time I seem to upgrade the firmware I run into troubles with past quads,Would you recommend updating to a certain firmware to help?Any advice is very much welcomed, I need to get this fixed, thank you.
  • Yes, move to 3.2.1; over 3 are much better releases, can you share photos from your build and logs enabling vibrations and compass can help others to help, if arms not are rigid, that's a problem too.
    • 3.2.1 hey?
      I'll give that a go today and see if there is any difference thanks,
      If there is any problems again I'll upload the logs to have a look at
      They arms are very flexible which is obviously not good I think I need to get a new frame
      • Perhaps shortening? or changing them? aluminium tubes works well
        • It's a DJ's flame wheel copy frame that's a 600mm, I should have known it was going to flex, it's my own fault,
          I've just purchased a legitimate dji 450mm flame wheel frame so that should help with no flex
          • There are many of dj here flying well, good luck.
Gremsy liked Gremsy's profile
Mar 12
DIY Robocars via Twitter
Nov 27, 2022
Nov 24, 2022
Nov 24, 2022
Nov 24, 2022
Nov 24, 2022
Nov 20, 2022
Nov 20, 2022
Nov 8, 2022
Nov 8, 2022
Oct 23, 2022
Oct 23, 2022
Oct 23, 2022
Oct 19, 2022
Oct 18, 2022
Oct 13, 2022
