0 APM 2.6 Fails to download parameters Posted by Sanjay Gupta on June 18, 2015 at 1:31pm Hi there!1.My APM 2.6 is not downloadind params stopping/hangs at 'PARAM RC4_REV'2.Please require urgent advice,(used the APM 2.6 only once on my Bumble Bee Quad) warm regards You need to be a member of diydrones to add comments! Join diydrones Email me when people reply – Follow
I must admit that I am also having issues with APM Planner and communications with the last version.
2 different computers, 2 different copters and the link keeps randomly dropping out.
Maybe this is the issue and not the APM after all.
I can not get APM Planner to work at all on my laptop only been using mission planner...
I've been doing some more testing and it seems if I disconnect everything but the GPS-Compass all
works fine, but when I connect the RC receiver that's when I seem to start locking up. I think I've narrowed
it down to the receiver whether I have it wired incorrectly or something in the receiver wrong not sure.
I have had this fault in the past and found if I reburn the firmware it went away.
I put it down to fault in the original firmware installation
Hi Mike,
Thanks for your input,so finally what is the way out how do I get my APM 2.6 back on track?
Is reset is the option if so how do you do that?
Mission Planner/Initial Setup/Load Firmware
Tried that many times but no joy!
UUUUggghhhhh i have a similar issue APM 2.6 lock up on firmware upload. Mission planner
freezes up just not having a good time with it right now getting frustrated....
