APM 2.6 Wont Arm Need 3D Fix
Looks like most of the posting here is quit old. But here go's.
When I try to Arm my Quad on Mission Planner, I get Check FS_THR_VALUSE
and GPS: No Fix.
Been searching for 2 days know. Can't find anything that helps.
I hope someone can help me with this arming problem.
              • What did you happen to do get it to work
                I have tried to get mine to ar for last 3 weeks
                Here is what I have tried
                Quad is a Hobby people F450
                Everything works on my quad copter up to the point where I go to arm it.
                Re installed firmware 3 times and done set up wizard 3 times.
                I can get all 4 motors to spin in Mission planner under test motors
                Verified my radio is working under mission planner(calibrated 3 time) and tested it on another plane.
                Purchased and 2nd APM 2.6 that gives same results.
                Tried 3 different power sources.
                Removed all add ons, sonar, video, etc and still will not arm.
                any help will be greatly appreciated.
                -Dustin
                Never get any messages while plugged in and never even tried to spin moters.  I have tested a 4 mots and calibrated speed controls and
            • Hi Mike
              Still no Arming luck.
              Mode: Stabilize
              Here is my settings. Radio ON, Throttle value (Ch3) 982,  FS 915
              Radio OFF, Throttle value (Ch3) 900,   FS 915
              No GPS Fix,   No PreArm messages come up on Flight Data Screen.
              I sure feal lost. Must be missing something.
              Is there any info you need to determine what mite be going on ?
            • Thank you for the help. I will post the results.
