Hi all,
I'm attaching my log from our last flight as our little quad went completly bonkers before it crashed.
Short after takeoff it went completly out of control, no response at all from RC or Telemetry and then crashed near a pond (thank god).
But the mistery was about to begin when we started reviewing the log and found out that the trigger was the failsafe error Err: EKF_CHECK-2 / Err: FAILSAFE_ EKF-1.
In understand these two were recently added to APM, but this ain't the first time I see this sort of thing happening.
I'm attaching my log in hopes for some guidance.
Thank you all!
http://copter.ardupilot.com/wiki/ac_measuringvibration/
Balance your props should improve that greatly
This looks fairly simple -
Bad vibrations => ErrYaw increasing => EKF error triggered.
Try graphing AccY & ErrYaw. AccY should not get above 3 tops, ErrYaw should stay below 0.2 - yours are getting to -5 and 1.0 respectively.
Not sure about the OP. No ErrYaw data at all which is weird. He seems to have a fast yaw change which the desired yaw cannot track (look at Yaw and DesYaw) and things unravel from there. I wondered whether this is an example of maxing out the IMU, in which case 3.3 should be better.
I apologize, I should have clarified. I am running arducopter 3.2.1 on a Pixhawk with a F450 frame. I have EKF turned off and yet seeing an EKF failsafe error.
thats much better to hear...am breathing again
I appear to be having the same problem - see also :
http://ardupilot.com/forum/viewtopic.php?f=100&t=7872
Just had same issue and it forced the quad into Land mode in a bad spot. I don't even have EKF enabled, why would the EKF failsafe kick in??
Hi guys,
I have the same error.
I look at my logs and found the error was subsys:16 & ECode 2 & 0
By this list: http://copter.ardupilot.com/wiki/common-diagnosing-problems-using-l..., it's cause by EKF/InertialNav Check, Bad Variance.
So visit to fix this: http://copter.ardupilot.com/wiki/configuration/ekf-inav-failsafe/
Alex
No more alarm with adding a GPS! ;)
1
2
3
4
5
of 5 Next
