APM EEprom export
Just wondering if anyone has a quick and easy solution for backup of an APM2.0 set of settings.
I've configured the APM just the way I need it, but want to re-flash the hardware with the HIL simulation, and don't want to wipe any of my settings.
Or do I have my wires crossed here, is the area of ATMega memory that the 156k of Arduplane 2.4 not used by the settings themselves...i.e. the Arduplane code goes into the bootloader/Flash - but the Settings all go into the EEprom which is where the Arduplane reads it from....in which case just sending the HIL code will not wipe the settings, but be complimented by it because the HIL code will use my same settings, and when I re-send the True Arduplane code up to it it will continue to use settings I've already configured as long as I don't go into "first time setup" mode and re-initialize everything...
Regards
    in the planner goto the parameter list, you can save the settings to file to load later
