APM glitch
i seem to be getting weird glitches in my logs, where the value goes many thousands of times higher than normal, but for only basically a single line.
there are no noticeble flight problems, and i have my quad flying very smoothly.
i originally thought it was vibrations, but my z accell is actually pretty good except for these glitches. and i get perfectly smooth video with no jello, which is on the same platform as the apm
i have flown around 12 batteries through, and some have these glitches, and others don't but nothing is noticeable in flight.
i have attached a small test flight log which has acouple of these glitches.
any ideas?
2013-05-05%2011-50%204.log
  • T3
    Try turning off some of what you are logging. The APM can't process all the info. Turn off RAW and MOTORS, they eat CPU cycles.
  • How are you downloading the logs? I see the same, using MissionPlanner in a VM on OSX. I should try and download the logs direct and see if the problem re-occurs...
