APM mission planner
I have got some problem with my Mission Planner(V1.2.8) .... I have used PRE_calibrate mode and then Once I run the script(after setting some initial values for the Quad) the attitude is dropping to 0. The sim_multicopter's values with respect the velocity is around "1.xxxx" or "0.xxx".
Can someone please help!!
    can you give more infor on your setup. ie is it HIL, is it SITL, what hardware. and what it is your trying to archive
