APM Mission Planner not launching
Beginner here, just trying to launch Mission Planner.  When running ArdupilotMegaPlanner.exe (1.1.56) I get an error window with a lot of text.  It starts out like this:
A Major error has occured : System.TypeInitializationException: The type initializer for 'SingletonCreator' threw an exception.
This implementation is not part of the windows platform FIPS validated cryptographic algorithms. at System.Security.Cryptography.MD5CryptoServiceProvider..ctor() at GMap.NET.GMaps.DecryptString
I can't copy and paste the screen but there are more errors about GMap.
I'm running a Windows 7 with .Net 4.0 x64.
(I noticed there are spelling errors in the message I typed but I've rechecked the error displayed and the spelling errors are there.)
Any help is greatly appreciated.  Thanks for your time!
Jeff
    all your settings look ok,
    so I would suggest going to the intel website and updating your graphics card drivers.
    • Oh, I change the display resolution and the mission planner is working now. Thank you.
  • Hi, I have the same problem. It is not an odd case.
    Which subkey to 0? I don't know much about Regedit.
    Thanks.
      the error is around "bitperpixel"
      you are using an odd colour depth. please change that.
    • If you double click the fipsalgorithmpolicy  you should get a window that will let you edit the subkey.  just type in a 0 if it shows anything else.  Make note of what it displays in that subkey before changing it so you can change it back should you experience adverse effects.
      • I have modified it and restarted the computer. Still have the same problem...
      update your graphics card driver.
      it doesn't support opengl
      • The odd thing is that Mission Planner works sometimes. But I can't get it running in these 3 days.
        I'm using Sony duo 11 laptop. Thanks
